Logitech's G933 Artemis Spectrum Wireless Gaming Headset is down to $60 for one day only
Woot has factory reconditioned models of the Logitech G933 Artemis Spectrum 7.1 Surround Sound Wireless Gaming Headset on sale in your choice of white or black for just $59.99 today only. This one-day sale saves you more than $50 off its average cost at Amazon, where it's recently sold for as much as $150.
Even though these headphones aren't brand new, they've been inspected, tested, and cleaned directly by Logitech to make sure they're in like-new condition before being shipped out. They come with a 90-day Logitech warranty too. Shipping at Woot is free for Amazon Prime members. If you're not a Prime member already, you can start a free 30-day trial to skip Woot's $6 shipping fee.
Logitech G Pro X Superlight wireless gaming mouse
$137.98 $150.00 Save $12
This mouse was made in collaboration with leading esports pros,, which means it's designed with intense and competitive gaming in mind. It weighs less than 63 grams. The Hero Sensor is designed for best possible performance.
Logitech G640 large cloth gaming mousepad black
$24.99 $40.00 Save $15
Gives the right amount of resistance to your mouse with low DPI gaming so you can be more precise. Surface provides a consistent texture for an even translation of mouse to cursor movement. Rubber bottom keeps it from slipping.
Logitech G613 Lightspeed wireless mechanical gaming keyboard black
$63.99 $79.00 Save $15
Includes Bluetooth and Logitech's Lightspeed wireless tech for a 1ms report rate. Uses Romer G mechanical switches that are very durable and can survive 70 million clicks. Has six programmable G keys and lasts up to 18 months on two AA batteries.
Logitech G305 LightSpeed wireless gaming mouse
$39.99 $60.00 Save $20
Includes Logitech's wireless USB receiver for a speedy connection. LightSpeed tech makes the responsiveness less than 1 millisecond. Includes a 12,000 DPI sensor, 250 hours of battery life, LED optical scanning, 6 programmable buttons, and more.
Logitech G502 Hero high performance gaming mouse black
$39.99 $50.00 Save $10
Uses high-performance 16K DPI sensor. Huge adjustable range as well. Has 11 customizable buttons with onboard memory so you can store different combinations per game. Has RGB lighting and LightSync to pair with other gear.
The G933 is loaded with Pro-GTM audio drivers, 7.1 Dolby surround sound, and DTS Headphone: X. It works on PC, Xbox, and PlayStation consoles. It can even work with your TV using USB or RCA outputs. The wireless battery lasts up to 12 hours, but you can use the analog cable as well. You can plug in up to three devices to answer calls, stream music, and more while gaming at the same time. It also has customizable RGB lighting, backlit tags, and three programmable macro keys.
