Logitech's G603 LightSpeed wireless gaming mouse has dropped to just $50
The Logitech G603 LightSpeed wireless gaming mouse is down to $49.99 on Amazon. This mouse usually sells around $60. We did see a one-day Amazon daily deal back in June when the mouse dropped as low as $43, but outside of that today's deal is its lowest drop.
The G603 uses Logitech's next-gen Hero optical sensor, which gives it extreme performance and power efficiency. With two AA batteries, you'll get 500 hours of non-stop gaming. The mouse will still work on one battery, too, so you can make it lighter if you want. The LightSpeed wireless technology has a 1 ms response time that's as fast as a wired mouse. You can use either LightSpeed or Bluetooth to easily connect multiple devices to the same receiver and switch between them with the push of a button. You'll find six programmable buttons along with on-board memory that saves your settings.
The G603 works with PC, Mac, and both Android and iOS tablets.
