The Linksys Velop home mesh networking system has dropped to just $130 on Amazon
Linksys Velop
Linksys Velop (Image credit: Linksys)
Grab the 3-pack Linksys Velop home mesh networking system on sale for $129.99 on Amazon. This is a great low price considering the Velop 3-pack normally sells for around $280. It has only dropped lower than this once before when it hit below $100 back in August.
Other than that, today's drop is the best deal we've seen. At this price, the 3-pack is the same cost as the 2-pack, and an extra Velop satellite would cost you around $86 bought by itself.
Linksys Velop 2-pack mesh networking system
$229.99 $349.97 Save $120
Linksys AC3200 WRT gaming Wi-Fi router
$150.00 $249.99 Save $100
Linksys Tri-Band WiFi Router for Home (Max-Stream AC2200 MU-MIMO Fast Wireless Router)
$119.99 $179.99 Save $60
Linksys Velop Tri-Band Home Mesh WiFi System - WiFi Router/WiFi Extender for Whole-Home Mesh Network (3-pack, White)
$370.00 $499.97 Save $130
$229.70 $349.97 Save $120
The traditional Wi-Fi setup is a modem with a router, which distributes a wireless signal as far as it can go. This is a problem if you have your modem setup in a weird spot or you just have a large house. I'm not talking about mansions here. Even a simple townhome with three floors can be a problem for a normal router because it can't fill every floor with solid, strong Wi-Fi. Mesh networking systems like the Velop make up for that by giving you several satellites you can distribute throughout your home. They all connect together and form a seamless Wi-Fi blanket. Once setup is complete, you'll be able to move around your house and not even notice that your phone is switching from one router to the next.
The Linksys Velop can cover up to 4,500 square feet in Wi-Fi, which is about the equivalent of a 3.5-bedroom home. It uses dual-band connectivity with speeds up to 867 Mbps and 400 Mbps per node. The Wi-Fi will be strong enough for 4K streaming, playing video games, and more. Plus, it can connect to any existing modem, even one provided by your ISP. The only thing you'll replace is your current router. You can use the Linksys app for easy setup and configuration.
