Light Flow LED Control updated to v3.0.4, fixes for Jelly Bean included
After the roll out of Light Flow LED Control v3.0, Google went ahead and introduced Android 4.1 Jelly Bean. This introduced some changes that needed to be corrected within Light Flow LED Control and now we're seeing v3.0.4 roll out to correct those issues as well as a few others:
  • Jelly bean fix - this hopefully fixes most of the issues
  • Gmail switching off fix
  • Fix for several crashes which playing notification sounds
  • Fix for Motorola ICS calendar
  • Fix initialization settings so notifications are enabled correctly
If you've been having issues with Light Flow on your Jelly Bean device, go ahead and fire up the Google Play Store and grab the update. If you're new to Light Flow you'll find the download link below. Keep in mind, there is a free version available use as well in case you want to test it out before going all in.
Download: Paid, Free Thanks, eljedo!
