Change up the mood with this LIFX BR30 Smart Bulb at $20 off
You are now subscribed
Your newsletter sign-up was successful
The LIFX BR30 Wi-Fi Smart LED Light Bulb just reached $39.99 at Amazon, and at one of its lowest prices in history, you do not want to miss out on the smarts this bulb could bring to your home. It regularly sells for up to $60, though its average cost is just under $50.
This smart bulb connects to your home Wi-Fi so you can control it with an app on your phone, no matter where you are at the time. You'll be able to schedule it to turn on and off at a certain time each day, see if you left the light on while you're away from home, and even turn it off from the comfort of your bed. You can voice control this light bulb too, though you'd need a device featuring Amazon Alexa, such as the Echo Dot. It's also compatible with Apple HomeKit and Google Assistant for voice control
Using the app, or your voice, you can change this bulb's color easily and quickly to fit any mood. It has over 16 million color options as well as warm to cool whites. It's bright too, equivalent to a 75W bulb, and doesn't require a hub for use unlike many other smart bulbs.
