LG's 27-inch 1440p Nano IPS monitor has dropped to $447
Lg Ultragear 1440p
Lg Ultragear 1440p
The LG 27GL850-B 27-inch Ultragear Nano IPS gaming monitor is down to $446.99 on Amazon. This monitor usually sells for around $500, and it has hardly ever dropped from that price. The only other time it dropped in price was a similar deal to this one that we shared in late January. Since then, though, it bounced back up to $500 or went out of stock altgoether. Grab it while you can before this deal disappears again.
LG 27GL850-B 27-inch Ultragear Nano IPS G-Sync compatible gaming monitor
$386.99 $450.00 Save $63
The specifications include a 1440p pixel resolution, a 144Hz refresh rate, and a 1ms response time. With an IPS panel, you get great viewing angles and color accuracy. Plus the native adaptive sync works with AMD and Nvidia graphics cards.
LG OLED55CXPUA CX Series 55-inch 4K OLED Smart TV 2020 with Alexa
$1,350 + Free Speaker
Deal works with larger TVs, too. The CX series includes an advanced processor for 4K upscaling, LG's webOS smart platform that can access all of your favorite content and streaming platforms, features like G-Sync just for gamers, and more.
LG 27GN800-B 27-inch 1440p IPS Ultragear gaming monitor
$296.99 $400.00 Save $103
A great monitor that includes a 2560 x 1440 pixel resolution, a 144Hz refresh rate, and a 1ms response time. It has an IPS panel for great viewing angles. It's also G-Sync compatible with FreeSync native support.
LG 27GN800-B 27-inch UltraGear 1440p gaming monitor
$346.99 $462.00 Save $115
Add the monitor and an Xbox controller of any color to your cart and you should see $114 taken off when you go to checkout, giving you the controller for free and reducing the price of the monitor to $347, which is what it's going for elsewhere.
LG UltraGear 24GN600-B 24-inch 1080p IPS monitor
$179.99 $220.00 Save $40
This is a model unique to Costco. The monitor has an IPS panel for great color accuracy. It also has a 144Hz refresh rate and 1ms response time. Includes FreeSync, two HDMI ports, one DisplayPort, and wall mounting capability.
No lie, I have been keeping an eye on this monitor since before its release last July. I even bought the budget version, the LG 27GL83-A over Black Friday. These monitors have been so popular since release thanks to the balance of price and features that just staying in stock has been difficult enough.
If you're a gamer, the specifications on this monitor are ideal. It's a 27-inch screen with 2560 x 1440 pixel resolution, a 144 Hz refresh rate, and a 1 ms response time. It also uses an IPS panel, which is crazy given that IPS panels usually have much slower response times. Some reviews have called it one of the fastest response times ever measured for a panel like this thanks to LG's Nano IPS technology.
With those stats and the adaptive sync technology built in, you won't notice any motion blur while gaming. It defaults to AMD FreeSync tech, which works with your AMD graphics card to reduce screen tearing. However, it's also officially compatible with Nvidia G-Sync, so you can use this with your Nvidia graphics card as well. Just plug in via DisplayPort to get that G-Sync tech working along with the best 144 Hz refresh rate.
It comes with an ultra-thin bezel and a stand that is tilt, height, and pivot adjustable. You can also forego the stand for a wall or arm mount with the Vesa 100 x 100mm standard.
