LG G Flex 2 specs
The LG G Flex 2 takes what we got from LG's first flexible phone and pumps it up for 2015. You get the same sort of look and feel — a large-ish phone that bends but doesn't breaks when you put pressure on it. But LG has addressed many of our chief complaints of the late-2013 model and has brought forth a phone that sits nicely between the LG G3 and what we expect to see in the company's flagship device for 2015.
These, now, are the complete LG G Flex 2 specs.
Swipe to scroll horizontally
CategoryFeatures
Display5.5-inch 1080x1920 Plastic OLED (403 ppi)
Operating systemAndroid 5.0 Lollipop
ProcessorQualcomm Snapdragon 810 at 2.0 GHz
RAM2GB or 3GB LPDDR4, depending on region
Storage16GB or 32GB eMMC, microSD card
Rear camera13 megapixels with OIS+, laser autofocus, dual flash
Front camera2.1 megapixels
Network3xCA, 300Mbps theoretical max
Battery3,000 mAh non-removable with quick charging
Size149.1 x 75.3 x 7.1-9.4mm
Weight152 grams
ConnectivityWifi 802.11 ac, Bluetooth 4.1, USB 2.0, NFC
