Fill your room with any color using two dimmable Koogeek smart bulbs on sale for $19
You are now subscribed
Your newsletter sign-up was successful
Switching up the mood in your bedroom or living room is pretty simple with tech like Koogeek's Dimmable LED Wi-Fi Smart Bulbs. They not only can be controlled with an app on your phone but also using your voice and Amazon Alexa, Google Assistant, or IFTTT. Today they're even more affordable than usual when you enter promo code DYVK2FGD during checkout at Amazon; that'll drop the two-pack of bulbs down to just $19.19, which is just a couple of dollars higher than a single bulb normally sells for.
These smart bulbs take just a few minutes to set up and pair easily with an app on your smartphone or tablet. From there, you'll be able to dim the lights, turn them on or off, schedule one to be on at a certain time each day, and switch between over 16 million colors. They're capable of being controlled together or separately and even come with a 12-month warranty.
One of the best features of these smart bulbs is their voice command functionality, though you'll need a compatible device to unlock that feature, such as the Google Home Mini or Amazon's Echo Dot. Luckily, both are on sale right now around $30 so you can save $20 on the purchase of either.
