Keep an eye on baby with Eufy's SpaceView 720p monitor down to $116
The Eufy SpaceView 720p security video baby monitor is down to $115.99 on Amazon. That price comes thanks to a drop from $160 to $136 and then an on-page coupon taking another $20 off. This brings it down to the lowest direct price we've seen since before Black Friday. That's a lot of savings for one of the better baby monitors around.
Eufy cordless stick vacuums and robot vacuum cleaners
As low as $140
Choose from a cordless stick vacuum or a robot vacuum. The cordless vac includes 120AW suction power for 8 minutes or 25 minutes in standard mode. Helpful for getting into tight spaces. The robot has 1300Pa suction and lasts up to 100 minutes.
Eufy Security Wi-Fi 2K resolution video doorbell
$119.99 $160.00 Save $40
You'll get a wireless chime you can use somewhere else in the house to hear the door wherever you are. Has a 2K resolution image with advanced HDR and distortion correction. Includes two-way audio, motion detection, and smart alerts.
Eufy RoboVac 15C Max Wi-Fi connected robot vacuum cleaner
$175.99 $ Save $
Comes with super strong 2000Pa suction so it can pick up even stubborn dirt. BoostIQ feature will even boost the suction when you need it. Lasts for up to 100 minutes. Use the EufyHome app and connect it to your smart home for more control.
Eufy Spaceview Security by Anker baby monitor camera bundle
$129.99 $170.00 Save $40
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Can pan 330-degrees and tilt 110-degrees so you can see the whole room. Get instant alerts. Has a range up to 1,000 feet.
Eufy Security SpaceView 720p video baby monitor with night vision
$109.99 $160.00 Save $50
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Includes a wide-angle lens for when your baby starts moving around more. Get instant alerts. Has a range up to 1,000 feet in open area.
This baby monitor lets you both see and hear your little one. The 5-inch 720p display is better than most monitors you'll find on the market, and there's a wide-angle lens included for when your kid transitions from crib to climbing-out-of-the-crib-and-wreaking-havoc. Fun times. You can tilt and pan the lens to see corner-to-corner, and there's a wall mount included for customized coverage. The night vision mode allows you to see in the dark.
This also has some nice features to help you relax. The built-in thermostat shows you at a glance what the temperature of the nursery is. The Smart Alert system notifies you when your baby is crying, and those combined with the video feed means you won't have to get up to double-check. Finally, if a lullaby is needed, the two-way voice communication lets you speak to your child from up to 460 feet away.
ife pro tip: You're going to spend about as much time staring at your baby monitor hoping your baby calms down and goes to sleep as you will actually sleeping... so you want one that's nice to look at! Lucky you, you can also save a chunk of change while you're at it.
