Jabra's Elite Active 65t true wireless earbuds are down to just $50 refurbished
The refurbished Jabra Elite Active 65t true wireless earbuds have dropped to $49.99 on Newegg. These are refurbished and sold by the Jabra Online Store, the official manufacturer. This is part of a unique 2-day sale at Newegg, and you'll find the same earbuds being sold refurbished by Jabra at other retailers like Amazon for twice as much. Brand new they cost $117 or more.
Jabra Evolve 75 Bluetooth headset for the office
$216.80 $280.00 Save $63
The headset produces incredible audio with world-class speakers and has crystal clear voice communication, too. Advanced mics use active noise cancellation to keep your calls clear and the ambient noise gone. Lasts up to 30 hours.
Jabra Elite Active 65t true wireless earbuds titanium black
$69.99 $100.00 Save $30
The earbuds have Bluetooth, up to 5 hours of battery on a single charge, and up to 15 hours total using the charging case. Also rated against sweat and dust. Work with voice assistants. This price available in three different colors.
Jabra Elite 65t true wireless earbuds titanium black best buy
$49.99 $80.00 Save $30
The 65t have dual mics and true wireless Bluetooth stability that helps reduce audio drops. They will last up to 5 hours on a single charge of the battery with an extra 10 hours from the charging case. Also available at Best Buy.
Jabra Elite 65t true wireless earbuds titanium black headphones
$64.99 $80.00 Save $15
Five hours of battery life plus up to 15 hours with the charging case. Four mics help reduce noise and wind when taking calls. Passive noise cancellation to block unwanted sound. IP55 rating resists dust and water. Connect to voice assistants.
Jabra Elite 75t active noise-cancelling true wireless earbuds
$119.99 $150.00 Save $30
Active noise-cancelling filters out the world. Includes 4-mic call tech that helps eliminate wind and noise. You get 7.5 hours of battery life per bud with a total of 28 hours using the charging case. Has customizable equalizer and no audio dropouts.
The Elite Active 65t earbuds are an upgrade over the basic Elite 65t. The Active in the name denotes exactly what they're doing, giving you some protection for a more active lifestyle. They have built in water resistance and dust resistance with an IP56 rating, which means you can use these at the gym or while outside without worry about ruining them. It also comes with a selection of earbud tips to ensure you get the perfect fit. These things should not be falling out of your ears even when you're running or working out.
You'll also get up to 5 hours of battery life on a single charge with the earbuds. The case carries some extra charge so you can get a total of 15 hours before you ever need to plug in. One fault of the Jabra earbuds lineup is that you can't use the two earbuds completely independently. The left earbud is always dependent on the right one, although you can use the right one alone if you want. But Jabra has a big focus on the quality of the audio and wants the earbuds to be used together anyway. You'll even get a customizable equalizer available through the app that lets you personalize your music.
Since these are refurbished directly by Jabra, they are covered by Jabra's own return policy. Plus the manufacturer promises they have been professionally restored to work like new. All the accessories have been inspected and cleaned, and the only issue you'll find is minor blemishes.
