The Jabra Elite 65t true wireless earbuds can be yours for $88 refurbished
The Jabra Elite 65t 3rd-gen true wireless earbuds are down to $87.99 through Newegg Flash, Newegg's temporary deal site. These earbuds sell for around $100 when refurbished at other sites like Amazon. The same earbuds brand new go for around $140 at the moment. Either way, Newegg's price is one of the best we've seen.
Jabra Evolve 75 Bluetooth headset for the office
$216.80 $280.00 Save $63
The headset produces incredible audio with world-class speakers and has crystal clear voice communication, too. Advanced mics use active noise cancellation to keep your calls clear and the ambient noise gone. Lasts up to 30 hours.
Jabra Elite Active 65t true wireless earbuds titanium black
$69.99 $100.00 Save $30
The earbuds have Bluetooth, up to 5 hours of battery on a single charge, and up to 15 hours total using the charging case. Also rated against sweat and dust. Work with voice assistants. This price available in three different colors.
Jabra Elite 65t true wireless earbuds titanium black best buy
$49.99 $80.00 Save $30
The 65t have dual mics and true wireless Bluetooth stability that helps reduce audio drops. They will last up to 5 hours on a single charge of the battery with an extra 10 hours from the charging case. Also available at Best Buy.
Jabra Elite 65t true wireless earbuds titanium black headphones
$64.99 $80.00 Save $15
Five hours of battery life plus up to 15 hours with the charging case. Four mics help reduce noise and wind when taking calls. Passive noise cancellation to block unwanted sound. IP55 rating resists dust and water. Connect to voice assistants.
Jabra Elite 75t active noise-cancelling true wireless earbuds
$119.99 $150.00 Save $30
Active noise-cancelling filters out the world. Includes 4-mic call tech that helps eliminate wind and noise. You get 7.5 hours of battery life per bud with a total of 28 hours using the charging case. Has customizable equalizer and no audio dropouts.
The 65t have dual microphone technology and true wireless Bluetooth stability that helps reduce audio drops. They will last up to five hours on a single charge of the battery with an extra 10 hours of battery life within the charging case itself. That means you can spend most of the day no where near a wall outlet and without a charging cable and still listen to your favorite tunes.
These headphones also feature one-touch access to Alexa, Siri, or Google Assistant, which can make your life so much easier when it comes to remembering appointments or dealing with smart home technology.
Daniel Bader's review of these earbuds gave them 4.5 stars out of 5 along with a "The Best" award. He called the earbuds "nearly flawless" and said "If you've been looking for a pair of truly wireless earbuds that don't look like protruding white ear tubes and actually sound like a decent pair of headphones, Jabra's got your back."
Curious about earbuds but still looking to save? Check out the TaoTronics true wireless earbuds on sale for $30. You'll still get good sound, a long battery life, and an assortment of ear tips to help you find the perfect fit.
