Get iVANKY DisplayPort cables at super low prices for Black Friday
iVanky DisplayPort
iVanky DisplayPort (Image credit: Android Central)
Great cables can really change the connectivity experience. While there are plenty of low-cost cables that come at only a few bucks on Amazon, these cables usually don't support the latest standard, don't often last long, and ultimately cost more than they're worth considering you have to buy new ones all the time. That's exactly where iVANKY comes in, with a range of high-end DisplayPort cables that don't break the bank, and in fact, are even cheaper for Black Friday.
There are four iVANKY DisplayPort cable models on offer, and they're all very inexpensive. There are models for users who simply want a DisplayPort cable that supports the latest standards, and there are HDMI to DisplayPort cables, and so on. Safe to say, no matter what you need, iVANKY should offer something for your needs.
We've been using iVANKY's DisplayPort cables for a while now to find out just how well they perform.
Models
As mentioned, there are four iVANKY DisplayPort cables on offer by the company, and those cables come in varying lengths. Here's a quick rundown.
The first cable is the basic iVANKY DisplayPort 1.2 cable, which is so high-end, that it has actually become the Amazon Choice pick for DisplayPort cables, thanks to its 4.7 star average rating and over 8K reviews. The cable is available in a range of colors, including 3.3 feet, 6.6 feet, 10 feet, and 15 feet, so there should be something for the vast majority of users.
The next model is an upgraded version of that top-selling cable. It supports 4K, and has new tin plates to better shield against interference for a slightly more stable connection. This cable is available in 3.3 feet, 6.6 feet, and 10 feet options.
Next is the iVANKY DisplayPort 1.4 cable, which supports 4K video at up to an impressive 144Hz, or 8K video at 60Hz. That's pretty impressive -- and means you'll get clear movement on the display without dropped frames. The cable is available in 3.3 feet, 6.6 feet, 10 feet, and 15 feet.
iVANKY DisplayPort
Source: Windows Central (Image credit: Source: Windows Central)
Last but not least is the iVANKY DisplayPort to HDMI cable, which is perfect for those who want to use a HDMI screen with their DisplayPort-only computer. It supports a 4K resolution at up to 60Hz, and offers a latch-free design to easily remove the cable without damaging the port itself. This cable is available in 3.3 feet, 6.6 feet, and 15 feet options. Keep in mind that it is uni-directional, so it only supports a DisplayPort computer or source, and HDMI display.
Design and build
The first thing to notice about these cables, no matter which model you go for, is how well-built they are. No matter which model you go for, and no matter which length of it you get, the cable is clearly strong and able to withstand any day-to-day abuse that you can throw at it.
That strong build largely takes the form of a braided nylon sleeve that protects the cable from any twists, pinches, or anything else that could usually damage a cable. The connectors are high quality too. They're seamlessly integrated into the rest of the cable to prevent them from being a breaking point for the cable -- essentially meaning that from tip to tip, the cable is strong and durable.
Low cost and high quality
Ultimately, iVANKY's DisplayPort cables are kind of a no-brainer. They're relatively inexpensive, but offer a far superior build quality than most of the other options in the price range. Add the fact that the cables are available in a range of different sizes and models, and there's something there for everyone.
You can get iVANKY DisplayPort cables for yourself straight from iVANKY's online store.
