The iRobot Roomba E5 self-charging robot vacuum has matched its low price of $279
The iRobot Roomba E5 5150 robot vacuum cleaner is down to $279 on Amazon. That matches the lowest price ever on this robot vacuum, a price we've only seen once during the Black Friday shopping season. It has been selling for around $330 since last September when it dropped from $400. You can find this price matched at a couple of other retailers like Best Buy and Target, and it regularly sells as high as $375 at those stores.
iRobot Roomba i4 4150 Wi-Fi robot vacuum cleaner
Latest Videos From
$279.99 $350.00 Save $70
Similar to the Roomba i3 that is sold elsewhere. Has a premium 3-stage cleaning system with 10x the suction. It can navigate and map your home. Works on wood and carpet. Has reactive sensor technology so it knows where it can and cannot go.
iRobot Roomba 675 self-charging robot vacuum cleaner
$199.99 $250.00 Save $50
The Roomba 675 has a 3-stage cleaning system and dual multi-surface brushes so it can go from hard floors to carpet. Voice compatible with Google Assistant and Amazon Alexa. Has adaptive navigation and learns your habits. Can recharge itself.
iRobot Root rt0 coding robot programmable STEM toy
$99.99 $150.00 Save $50
Includes a Brick Top that's compatible with Lego and other building blocks so you can turn your robot into whatever you want. Teaches coding with 3 learning levels using lessons, projects, activities, and hands-on problem solving.
iRobot Roomba i6+ 6550 self-emptying self-charging robot vacuum cleaner
$549.99 $800.00 Save $250
Set up a schedule, set up the charging dock, and connect it to your smart home. After that the only time you ever have to worry about your new robot vacuum is when the charging dock's bag is full because it empties its bin on its own. Awesome.
iRobot Roomba Robot Vacuum deals
from $179
Select Roomba smart vacuum cleaners by iRobot are currently on sale for Cyber Week! These low prices match the stellar savings we saw during Black Friday and Cyber Monday, though they won't last forever so be sure to shop soon if you're interested.
The Roomba E5 has 5x the air power of the Roomba 600 series, which is another popular lineup from iRobot. The robot vacuum is great for homes with pets because it has a premium three-stage cleaning system. This system ensures the E5 can clean up dirt and dust but also pet hair and the allergens produced by cats and dogs and other animals. The filter can trap 99% of allergens. The robot vacuum's dustbin is washable so you can easily clean out the debris it picks up without it being irritating to you.
The rubber brushes are designed to go over multiple surfaces so it can adjust to stay in constant contact. Let it loose on carpet and hard floors and more and it will adapt accordingly. The sensors underneath the robot help it navigate these changes. Plus it can find its way around objects and under furniture.
The battery on the E5 can run for 90 minutes continuously. It's also smart enough to return to its charging station when it runs low so it can top off and then continue its mission.
You can control the robot vacuum from your phone using the iRobot app. You can also issue voice commands through Amazon Alexa or Google Assistant if you connect the robot to your Wi-Fi network. Users give the E5 4.3 stars out of 5 based on 702 reviews.
