Invest in your home with sixteen Philips LED light bulbs at over 30% off
Once you replace all of your light bulbs with LED versions, you'll wonder why you ever waited so long. They're better for the environment, and also much kinder to your wallet than traditional incadescent versions. Fully outfit your home in LED goodness with 16 Philips LED Non-Dimmable A19 Frosted White Light Bulbs for $17.89 at Amazon. This same quantity would usually cost you around $10 more than you'll pay today. You might even be eligible for a lower out-of-pocket cost if you use Subscribe & Save. That'll also get you free shipping, whereas buying the bulbs outright requires either Amazon Prime or a $25 order for complimentary shipping. Canceling Subscribe & Save subscriptions is super easy and Amazon will email you a reminder before any future orders ship.
Philips SmartSleep wake-up light
$79.95 $100.00 Save $20
Simulates the sunset and sunrise and includes 5 different wake-up sounds. Has an FM radio with snooze and automatic dimmable display. It also includes 10 brightness settings. Help establish a healthy sleeping and waking routine.
Philips Hue white & color BR30 starter kit
$69.99 $120.00 Save $50
The kit includes two multicolor BR30 smart bulbs and the Philips Hue bridge designed to help you unite your bulbs and connect them to your Wi-Fi network. Find the perfect lighting with preset scenes or lighting effects that sync to your movie.
Philips Audio Fidelio X2HR over-ear open-air headphones
Up to 20% off
The X2HR have Hi-Res Audio with 50mm high-def neodymium drivers and an acoustic open-back architecture. They have deluxe memory foam ear pads and a lightweight adjustable hammock with genuine leather.
Philips SmartSleep Connected sleep and wake-up light therapy lamp
$169.99 $200.00 Save $30
Built-in bedroom sensor and smartphone connection helps create ideal environment. AmbiTrack sensor measures your bedroom's temp, noise, light, and humidity. Customize the alarm, light, sound, and sunrise/sunset themes. Has clock and touch display.
Philips goLITE BLU Rechargeable Energy Light
$130.40 $137.79 Save $7
LED bulbs consume much, much less energy than their incandescent counterparts. That means you'll probably save a ton of cash on your next power bill. Each bulb has an estimated 10-year lifespan, so you won't have to replace them for a long time, which means you'll save even more money in the long run. These bulbs provide soft white light that won't flicker, strobe, glare, or fade. They're compatible with E26 medium screw bases and they are not dimmable. So far, over 3,500 customer reviews have left these bulbs with an average of 4.3 out of 5 stars.
Note that these are not to be confused with Philips Hue bulbs. If you're looking for a smart lighting solution or fancy color changing options, go for something like this Philips Hue Starter Kit. It's actually on sale for a limited time, so now is the perfect time to purchase if you're in the market. We also have a handy roundup of the best Philips Hue alternatives in 2019 if you want to browse even more options. You might be interested in a list of the best smart home products under $100 too.
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
