Illuminate your home with TP-Link's Kasa multi-color smart light strip on sale for $54
The TP-Link Kasa KL430 multi-color smart LED light strip drops to $53.99 through the official Kasa eBay store when you add it to your cart. It is already discounted to $59.99, which is $10 better than other retailers like Amazon. Plus, Kasa's eBay store is discounting everything by 10%, so you get double the savings today. And we have never seen it sell for this low anywhere.
TP-Link Archer AX3000 Wi-Fi 6 wireless router
$99.00 $130.00 Save $31
Wi-Fi 6 promises speeds up to three times faster than previous generations with four times the bandwidth capacity and 75% lower latency. The router has MU-MIMO tech to cover multiple devices connected at once and Ethernet for wired connections.
TP-Link Kasa KP400 smart outdoor plug 2-pack
$29.99 $50.00 Save $20
Get free shipping with your Prime membership. Each plug has two outlets that can be controlled together or individually. Use your phone or voice control with Google Assistant or Amazon Alexa to control them from anywhere. Weather resistant.
TP-Link Archer A20 AC4000 Tri-Band Wi-Fi router
$139.99 $200.00 Save $60
With a tri-band radio, MU-MIMO technology, Beamforming, link aggregation, and more, this router is perfect for homes with a dozen different devices all trying to connect at once. It supports Windows, Mac, and Linux. Includes a 2-year warranty.
$16.99 $25.00 Save $8
With two outlets you can control two outdoor devices either together or individually. And you can do it from anywhere using your phone or voice control through Google Assistant or Amazon Alexa. Weather resistant with long Wi-Fi range.
TP-Link Archer C7 AC1750 Wi-Fi 5 dual-band router
$49.99 $80.00 Save $30
This great little budget router is capable of data transfer speeds up to 1750 Mbps with 2.4GHz and 5GHz wireless bands. Also has four Ethernet ports for a wired connection. Includes a quick and easy setup wizard.
Kasa's light strip is packed with all kinds of features. It's an 80-inch (just under seven feet) strip of LEDs. If you need it to be smaller, there are markers along the strip where you can cut it to make it fit in a smaller space. If you need it to be longer, you can add other Kasa light strips with a secure four-pronged connector that can increase the length up to 33 feet.
Use the advanced animated lighting effects. You'll have dozens to choose from and they help you create a unique lighting experience. This includes options like "Rainbow" or "Raindrop" among others. Connect the strip to your Wi-Fi and your smart home and use Amazon Alexa or Google Assistant to control it with your voice. Turn it on or off or even dim the lights. You can adjust the brightness from nothing to up to 1400 lumens. That's great for helping you set the mood whether you're having an intimate dinner or a racous party. The strip also features 16 color zones so you don't have to work out colors for the individual lights but rather change the color based on a larger zone of lights.
The strip doesn't need a hub or anything either. Just use the Kasa Smart app on Android or iOS for simple setup. You can follow simple on-screen directions and get everything connected in no time at all.
