The iClever 10W wireless car charger has dropped to just $24 on Amazon
The iClever 10W wireless car charger is down to $24.14 on Amazon. You get that price by clipping the 5% on-page coupon and using the code MOUNT2599 during checkout. The two discounts stack together to drop the price from $37 to the $24.14 deal. And in fact, the charger tends to sell for a couple bucks more regularly so you're saving even a little bit extra there. This deal won't last forever as coupon codes tend to just disappear pretty quickly, so grab one while you can.
Give your Android phone a maximum of 10W of wireless charging power. Your iPhone can go up to 7.5W and other Qi-enabled devices can go up to 5W. The iClever mount is smart enough to know which device is being mounted to it and provide as fast a charge as possible.
It's smart in some other ways, too. For example, it has an automatic infrared touch sensor. This sensor will cause the holder to automatically open when you place your phone near it so you can quickly and easily secure your phone and clamp it in. This makes placing your phone a really simple experience and something you can do with one hand. All you have to do after that is align the center of the phone with the charging coil. This power still works even when you turn off the car because it requires very little to power it, but there's also an emergency release button if the Touch Sensor ever stops responding for whatever reason.
The charger has built-in protections against things like over-charging, over current, over voltage, short circuits, and more. You will keep your gear and your car safe from anything like that. Choose where you want to mount it with the ability to mount on an air vent or on your windshield or dashboard using the suction cup. It has a 360-degree rotating ball joint, too, which supports your phone in any position.
