Grab the excellent HyperX Cloud II gaming headset and a carrying case on sale together for $77
At Walmart you can get the red HyperX Cloud II Pro gaming headset and a carrying case bundled together for just $76.88. That's a great price even for the headset alone, since it goes for $88.90 by itself at Walmart and Amazon. The case goes for around $13 by itself, so you're saving $25 on the combo.
HyperX Alloy FPS Pro tenkeyless mechanical gaming keyboard black
$54.99 $75.00 Save $20
A very minimal keyboard for mechanical gamers who don't need a numpad. Uses Cherry MX Red switches for durability and clickiness. Portable design includes detachable cable. Has anti-ghosting and N Key rollover. Red dynamic lighting effects.
HyperX Alloy FPS RGB mechanical keyboard
$64.99 $110.00 Save $45
A full-size keyboard that still uses a compact design for ideal gameplay. The solid steel frame is very durable, and it's also super portable with a detachable cable. Uses Kailh Silver Speed mechanical switches and full RGB backlighting.
HyperX ChargePlay Clutch Qi wireless charging mobile phone controller grip
$35.70 $50.00 Save $14
Includes textured, comfortable grips. Has its own 3000mAh detachable battery pack and can charge any Qi-compatible phone while you play or via USB if not wireless. Compatible with phones 5.08 to 6.77 inches in length.
HyperX Quadcast USB condenser gaming microphone Red LEDs
$125.00 $140.00 Save $15
The mic comes with an anti-vibration shock mount, a tap to mute sensor with LED indicator, and four selectable polar patterns. There's also a convenient gain control adjustment. It's compatible with multiple devices and plenty of chat programs.
HyperX headsets, keyboards, and mice sale
As low as $20
Get the Pulsefire Core mouse for as little as $19.99. The Cloud Flight headset with a 30-hour battery life is on sale for $40 off. The Alloy Origins Core tenkeyless mechanical keyboard is down to $64.99 from $90. Save on even more in the full sale.
This is the sort of headset that does gaming right. It has 7.1-channels of virtual surround sound, 53mm drivers, noise and echo canceling for the mic, memory foam ear pads for ultimate comfort, and it's certified to work with PC, Mac, PS4 and Xbox. Amazon users give it 4.1 stars based on more than 5,000 reviews.
