This huge deal saves you $94 on Brother's monochrome laser printer
The Brother HL-L2395DW monochrome laser printer dropped to $99.99 at several retailers recently, including Staples. That's already a huge discount and one of the printer's lowest prices ever. However, you can also use the coupon code 53834 at Staples to get another $25 off orders of $100 or more. So, all you need to is add a filler item like this box of paper clips that costs less than $1 and you'll be able to use the code to save another $25. Getting a fantastic printer like this for just $75.78 is a steal, and you can bet this price won't last long.
Brother DCPL2540DW Wireless Compact Laser Printer
Article continues below
$167.00 $188.06 Save $21
$167.17 $150.00 Save $-17
$166.96 $150.00 Save $-17
$168.00 $150.00 Save $-18
Because Brother printers are monochrome, they eliminate a lot of the issues you normally associate with printers. You won't go through toner quite as fast since you can store a whole lot of black ink. And you don't have to sit around reading a book and learning calculus while waiting for the printer to finish. It is super fast and can print up to 36 pages per minute. The carrying tray also has a 250-sheet capacity so you won't have to worry about replacing the paper for a while. The tray can handle both letter and legal sized paper.
You can also use wireless connections beyond Wi-Fi, including AirPrint and Google Cloud Print, to print from your computer, smartphone, tablet, and more. You can even use NFC and the printer's "Touch to connect" feature to print from your mobile devices without connecting directly to it.
In addition to printing, it comes with a glass flatbed scanner that can be used for copying and scanning quickly. It even has the ability to can scan straight to the Cloud with services like Dropbox and Google Drive. Print from those sources, too, if you use them for documents.
The toner will last you quite a long time, but you can always stock up on a little extra if you want. The Brother toner cartridges on Amazon are not overly expensive and will survive as much as you can print.
