How will game installation work on the PS5?
Best answer: Games on PS5, whether physical or digital, can be installed in configurable blocks, allowing players to download only certain sections, like either the single-player or multiplayer.
- Nearly limitless choices: PlayStation Store Gift Card (From $10 at Amazon)
- Coming soon: PlayStation 5 (See at Amazon)
How does game installation work right now on PS4?
Right now it's all or nothing. You either download the entire game, or you delete the entire game. There is no middle ground. Some games do allow you to choose which component is downloaded first — like the single-player or multiplayer — so that you can hop into whichever you want right away before the game installation completes, but the entire game will still need to be downloaded.
Game installation on PS5 will be more configurable, according to an interview between Mark Cerny and Wired. "Rather than treating games like a big block of data... we're allowing finer-grained access to the data."
This means that players should be able to choose which parts of games they want to download, like just the single-player or multiplayer. Players could even install the entire game and decide to uninstall the single-player campaign once they've beaten it, leaving the multiplayer component ready to play and freeing up storage space on the console.
Do physical games still need to be installed?
Be an expert in 5 minutes
Yes. Just like with PS4, physical games on PS5 will still need to be installed. This does not mean that you can play physical games without the discs. The discs will still need to be used so that the PS5 can verify the game's license if you purchased a physical copy.
On the PS5 Digital Edition, you won't be able to play physical discs at all. Everything is downloaded directly to its internal SSD.
Jennifer Locke has been playing video games nearly her entire life. You can find her posting pictures of her dog and obsessing over PlayStation and Xbox, Star Wars, and other geeky things.
