How to switch the navigation button placement on the Galaxy Note 8
The Galaxy Note 8, like the Galaxy S8 before it, uses virtual navigation buttons — a big change, after years of capacitive buttons on Samsung devices. But the default orientation places the back button to the right of the home button. If you're not a fan of the default settings, there is a way to change it, and a few things you can do to customize what your navigation bar looks like. We've got the details on how to adjust your navigation bar so that it looks the way you want it to.
- How to switch placement of navigational buttons
- How to change the background color of your Navigation bar
While the navigation buttons on your Note 8 are set to a default order of Recent - Home - Back, you can adjust this order. You don't have full autonomy over which buttons go in which order, but you can choose between the default or Back - Home - Recent.
- Open Settings.
- Tap Display.
- Scroll down and tap Navigation bar.
- Tap Button layout.
- Tap the new Button layout that you want to use.
If you like to have a bit of flair on your screen, then changing the color of the navigation bar is a fun, and easy way to do it. You get access to a few different shades, all of which can be swapped out whenever you feel like it.
- Open Settings.
- Tap Display.
- Tap to choose a new color for your Navigation bar.
Questions?
Do you still have questions about customizing your navigation bar? Have you experimented with switching up buton placement, or background color? Let us know in the comments below!
Be an expert in 5 minutes
Jen is a staff writer who spends her time researching the products you didn't know you needed. She's also a fantasy novelist and has a serious Civ VI addiction. You can follow her on Twitter.
