How to stream The Weather Channel once you've cut the cord
Best answer: The Weather Channel is available on frndly TV, Fubo TV and on three plans from AT&T TV Now.
The Weather Channel streams on a scant few services
It seems crazy, but if you're a cord-cutter looking to stream The Weather Channel, there only are a few services on which you'll find it. It sounds crazy, I know. And those services are Fubo TV, AT&T TV Now (that's the former DirecTV Now, of course), and the new frndly TV.
Fubo TV has been growing in popularity in good part because of its mix of channels. It's got many of the major networks you want, and it has a wealth of add-ons that will bring you sports you can't find anywhere else. Fubo TV also is the only place in the United States where you'll find any sports streaming in 4K resolution. All that — and 88 channels in the lower-priced tier — for just $55 a month. (You'll get a free trial, too, of course.)
AT&T TV Now is a more expensive option to stream The Weather Channel. And it's a much more expensive option, at that. Because you don't get The Weather Channel on AT&T TV Now until you pony up for their $110-a-month "Choice" option. It's also on the $124-a-month "Xtra" plan and the $135-a-month "Ultimate" plan. OK, unless Spanish is your first language — it's also on the AT&T TV Now "Optimo Mas" Spanish-language plan, which is just $86 a month. But otherwise, that's it.
Frndly TV is relatively new and is the brainchild of a former Sling TV executive. It only features a dozen live channels — but one of those happens to be The Weather Channel. Plans start at just $5.99 a month (you'll save a bit if you choose to pay annually, though), and you'll top out at a standard-definition feed. For HD, you'll pay $7.99 a month, and you'll also get the ability to stream on two devices at once, plus you'll get unlimited DVR, with recordings kept for 30 days.
Right now, those are your only options if you're looking for a way to stream The Weather Channel.
Technically there is one other option, though it's certainly in a bit of a gray area. The Weather Channel has an official channel (think "app," really) on the Roku platform. But you'll need to have a login to a pay TV service to activate it beyond the 10-minute trial. Those services are Dish, C Spire, Spectrum, Sudden Link, Optimum and Mediacom.
Watch The Weather Channel with Chromecast or AirPlay
This is one of those gray areas (OK, it's not really a gray area), and maybe it's a little more work than it should be. But whatever.
You can stream a live feed of The Weather Channel's website in a desktop browser, and then use Apple's AirPlay or Google's Chromecast to send that tab over to a TV.
Oh, and a catch — you'll need to have a cable login (from anyone other than Comcast) to sign in first. Maybe you tripped and landed on one and lo and behold, it works. Whatever. We're not going to judge too much.
Streaming alternatives to The Weather Channel
Yeah, it's ridiculous that The Weather Channel isn't everywhere, because it really should be. But that doesn't mean there aren't alternatives.
One such option is Local Now. (For which TWC is a weather provider.) It's not as slick as TWC proper, but it does have the same sort of "Locals on the 8s" thing.
Where to get Local Now? Sling TV has it in both its Orange and Blue plans. There's also an app for Amazon Fire TV. And there's also a Local Now channel on Roku, it's available on Fubo, and it's coming to YouTube TV at some point. And there are apps for Android and for iOS.
Phil Nickinson
Latest in Streaming & TV
Roku Remote
Roku’s autoplay ads on startup are rubbing users the wrong way
Disney+ logo with blue background
Disney's Andor Season 2 uses YouTube in a way we didn't expect
Chromecast with Google TV on top of Google TV Streamer
Google addresses older Chromecasts’ bug problem and is working on a fix
Google TV Streamer with Android figure and remote
Google's TV Streamer will reportedly skip availability in several overseas countries
The Chromecast with Google TV is officially no longer available for purchase
YouTube TV app on a smart TV
Paramount and YouTube TV finalize deal keeping CBS, CBS Sports available
Latest in How-to
Testing Google Pixel 9's camera
Your Pixel 9 lets you connect to remote cameras and film content from different angles. Here's how
Notification Cooldown on Google Pixel
How to enable Notification Cooldown on a Google Pixel
A Google Pixel 9 Pro XL in the bootloader recovery menu.
The March Pixel update has been causing lots of headaches, but going back isn't easy
The Modes menu on a Pixel 9 showing Do Not Disturb turned on
Modes have replaced Do Not Disturb on your Pixel. Here's how to use them
Google Messages blue logo
How to automatically delete OTPs in Google Messages
Weather and Calendar in Morning Brief on Galaxy S25 Ultra
How to set up and use Now Brief on the Galaxy S25
