How to reset location permissions in Android 11
It's great when Google gives users more control over their personal data and privacy like it's done in the latest Android release, and we're excited to show you how to adjust and reset your app location permissions in Android 11. Google first introduced more granular location and privacy controls in earnest with Android 10, but now it's taken that a step further and dialed it up to 11. Upon updating, apps that want to use your location will initially give you the option to grant access only while using the app, only this time, or you can deny it access. But what happens if you change your mind? Not to worry — here's what you need to do!
- Open the Settings app.
- Scroll down and tap on Location.
- Find the app whose permission you want to change from the Recent Location Requests or tap See all.
- Tap Permissions.
- Tap Location.
- Tap on the location access you want to give the app. You can choose from Allow all the time, Allow only while using the app, Ask every time, or Deny.
- If you want to see all of the apps that have this same permission, tap on See all apps with this permission.
- If you want to only give location access to the app one time, tap Ask every time.
- Open the app in question (in this case, Fitbit). You will now see the dialogue box again, giving you the option of granting location access Only this time.
The ability to grant an app a one-time permission is a game-changer on Android and something that you should definitely consider for certain apps. Now that you know how to change app location permission, you can modify it per app at any point in time to suit your needs and preferences.
Our top equipment picks
While many phones will be getting Android 11 soon, the Pixel line already has it. We think you can't go wrong with the affordable Pixel 4a.
Get Android 11 before anyone else
If you want to be among the first to use Android 11, the Pixel 4a is for you. The big draw is its guaranteed software updates and being first-in-line for them as they're released. You're also getting a fantastic rear camera, OLED display, snappy performance, and reliable battery life.
Have you listened to this week's Android Central Podcast?
Every week, the Android Central Podcast brings you the latest tech news, analysis and hot takes, with familiar co-hosts and special guests.
Be an expert in 5 minutes
Jeramy was the Editor-in-Chief of Android Central. He is proud to help *Keep Austin Weird* and loves hiking in the hill country of central Texas with a breakfast taco in each hand.
