How to remap buttons on a DualShock 4 controller
Most people don't know this, but you can actually remap nearly all of the buttons on a DualShock 4 controller in the PS4's settings. It's not a widely advertised feature so it tends to go unnoticed. If you find that you need to remap your controller in any way, doing so with a DualShock controller is much more convenient than going out and buying a premium controller to do the job. Remapping your DualShock is a simple process that should only take a few minutes at the most unless you take the time to test which button scheme works best for you.
How to remap buttons on a DualShock 4 controller for PS4
- Go to Settings.
- Select Accessibility.
- Scroll down and select Button Assignments.
- Select Enable Custom Button Assignments.
- Select Customize Button Assignments.
- Select which button you'd like to remap.
- Choose which button you'd like to remap it with.
- Select Confirm when you are done.
As nice as this feature is, there is still a limit to how much customization you can do. When you're remapping buttons you need to remember that you cannot remap two buttons to the same input. For example, if you remap X to O, then O will automatically be remapped to X, effectively flipping their positions on your controller. Both X and O cannot be mapped to O. Other buttons that you are unable to remap include the touchpad, start button, PS button, and share button.
Button remapping made easy
Not every controller supports button remapping directly through the PlayStation 4's settings, but the DualShock 4 always will. It's easy to get everything set up to take advantage of this valuable feature.
When you need a little something extra
The Astro C40 TR is a premium controller that offers button remapping directly through an app and comes with two extra back paddles to boot, making your life a lot easier should you need them.
Be an expert in 5 minutes
Jennifer Locke has been playing video games nearly her entire life. You can find her posting pictures of her dog and obsessing over PlayStation and Xbox, Star Wars, and other geeky things.
