How many Eero Pro 6 nodes do you need for your home?
Best answer: Each Eero Pro 6 node covers up to 2,000 square feet and keeps speeds high even with a weaker connection, thanks to a tri-band connection. Homes with a lot of interference will need more nodes to keep coverage strong.
Gigabit-speed mesh on the Eero Pro 6
A single Eero Pro 6 can cover up to 2,000 square feet. A three-pack will cover up to 6,000 square feet, though you'll probably have some overlap, which will take that top number down a bit. If you don't need much more than a single Eero can provide, you should make sure you need a mesh system.
Eero Pro 6 routers can be purchased individually and added to your mesh if you don't get enough coverage right off the bat. It may be tempting to add an Eero 6 Extender immediately, and while it will work, you'll only get around 500Mbps while connected to it. If you want to make the most of a gigabit connection, you must stick with the Pro models.
Don't forget that all Eeros will work together. If you have an existing Eero system, you can use your older Eero, Eero Pro, or routers or Beacons to expand your coverage in areas where speed isn't all that important. Of the current Eeros on sale, Eero Pro 6 has the greatest coverage of any Eero at 2,000 square feet, with the Eero and Eero 6 routers each covering 1,500 square feet. Keep in mind that neither of these smaller Eeros will be able to keep up with the gigabit speed of the core Eero Pro 6 mesh.
Eero has a tool to help you find a starting point for your mesh, but every house is different. It will also help you decide which Eero will work for you, though the Eero Pro 6 is the only one that will support full gigabit speeds.
The Eero app will help you position your Eero nodes in a place with a good signal. Just remember that if you're mixing different models, you should put the fastest Eero routers closest to the router to keep speeds as high as possible.
Be an expert in 5 minutes
Every house is different
Not all houses are built the same. Some have concrete or block walls that may block signals, while others may just have a more robust frame. Dense walls are a death sentence to 5GHz signals. This will be the case for every modern router, including the best Wi-Fi 6 routers. As a result, you may need more Eero nodes than you expected. You may also find a better fit with another one of the best Wi-Fi 6 mesh systems.
If you're still having trouble getting an adequate wireless signal to your Eero Pro 6 nodes, you can run an Ethernet cable from the router to the node to form a wired backhaul. This will be configured automatically. If you pair an Ethernet connection with a powerline adapter, you can provide up to a 1Gbps connection with your existing home wiring.
When Samuel is not writing about networking or 5G at Android Central, he spends most of his time researching computer components and obsessing over what CPU goes into the ultimate Windows 98 computer. It's the Pentium 3.
