How long does the battery last on the Jabra Elite 65t?
Best answer: The Jabra Elite 65t earbuds can get up to five hours of battery life on a single charge, though you can charge on the go with the included charging case.
Amazon: Jabra Elite 65t ($170)
Article continues below
According to Jabra, the Elite 65t should get up to five hours of usage out of a single charge. This can vary based on how you use your Elite 65t, however. If you use the headphones a lot when you're on a phone call, for instance, that could cause the battery to drain faster. Additionally, using the Hearthrough function, which lets you listen to the sounds of the environment around you, could also bring down the battery life of your earbuds.
Extend your buds' battery life with the charging case
The Jabra Elite 65t comes with a charging case that can extend the life of the earbuds when you're on the go. The case has enough power for 10 hours' worth of additional time for the earbuds, meaning you should be able to completely charge the Jabra Elite 65t twice before needing to charge the case again. The case itself charges via Micro-USB.
The charging case also lets you quickly extend the battery life of your Elite 65t if you need just a little bit more power. Throwing the earbuds into the case for about 15 minutes will get you around 90 minutes of listening time on the earbuds on top of whatever charge they had left.
