How to enable DeX Mode on the Note 9 with an HDMI adapter
There are plenty of HDMI adapters out there to use with DeX, but these are the best for your Note 9!
Products Used In This Guide
Any of those hubs will work with your Note 9, the only difference is what other equipment you already have. The ARKTEK hub is great if you plan to use a wired keyboard and mouse, the Uni cable should be used if you don't have a spare HDMI cable laying around, and the adapter from MOKIN is great if you do have an HDMI cable to spare.
How to use DeX with an HDMI adapter
  1. Plug your HDMI cable into your monitor or TV.
  2. Plug the HDMI cable into the hub or adapter, if necessary.
  3. Plug the USB-C side of the cable, hub or adapter into your Galaxy Note 9.
That's it! The DeX interface will show up on your monitor or TV. If you are using a dedicated keyboard and mouse you can use those to navigate the interface. If not, you can use the Note 9 as a trackpad and use its software keyboard for input.
Our top USB-C hub
You can get cheaper HDMI adapters if you just want to use DeX to stream videos on a big screen. But if you're serious about getting work done in DeX mode, a physical keyboard and mouse are essential. This hub will let you connect any wired keyboard and mouse, and it'll keep your phone powered up so you don't need to stop working.
