How to change the Side Key function on your Samsung Galaxy S or Note phone
Samsung Galaxy S20 Ultra Bader
Samsung Galaxy S20 Ultra Bader (Image credit: Android Central)
Samsung's latest phones, starting with the Note 10, have a multi-function "Side Key" that replaces the dedicated Bixby button. We primarily know it as a power button, but it can also have other functions for both double-press and long-press actions. It's super easy to set up and use — here's how.
  1. Go into your settings.
  2. Scroll down to advanced features and tap side key.
Source: Android Central (Image credit: Source: Android Central)
  1. You can leave it for quick-launching the camera.
  2. You can set it to open Bixby Home.
  3. Notably, you can't set the side key to open Google Assistant.
  4. If you set it to Bixby, you can access the power-off menu by holding power and volume down.
  5. Alternatively you can leave it in its default, launching the power-off menu, as it is on most phones.
Over time you're likely to switch around the functions of both the double-press and long-press actions on the Side Key as you find the combination that works best for you. That's what's great about it — you can set it up however you want as your needs change.
Andrew Martonik
Andrew was an Executive Editor, U.S. at Android Central between 2012 and 2020.
Latest in Samsung Galaxy
Galaxy A36 5G lifestyle ad
The Galaxy A36 5G was just announced, but you can ALREADY score $150 off at Samsung — here's how
The Galaxy S24 Plus in hand with a light behind it
Samsung's sixth One UI 7 beta for the Galaxy S24 rolls out as launch nears
The Samsung Galaxy S25 Edge on display
New leak shows off Samsung Galaxy S25 Edge in 'Titanium' variants
Leaked image of a blue Galaxy Z Flip 7
New Galaxy Z Flip 7 case leak backs rumors of a larger cover display
Samsung Galaxy Z Fold 6 on cobblestone road
One UI 7 Beta 3 for the Galaxy Z Flip 6, Fold 6 brings two notable AI additions
The Samsung Galaxy Tab S10+ on a desk.
Ditch Amazon and score 50% OFF the Galaxy Tab S10 Plus with this deal from Samsung
Latest in How-to
Testing Google Pixel 9's camera
Your Pixel 9 lets you connect to remote cameras and film content from different angles. Here's how
Notification Cooldown on Google Pixel
How to enable Notification Cooldown on a Google Pixel
A Google Pixel 9 Pro XL in the bootloader recovery menu.
The March Pixel update has been causing lots of headaches, but going back isn't easy
The Modes menu on a Pixel 9 showing Do Not Disturb turned on
Modes have replaced Do Not Disturb on your Pixel. Here's how to use them
Google Messages blue logo
How to automatically delete OTPs in Google Messages
Weather and Calendar in Morning Brief on Galaxy S25 Ultra
How to set up and use Now Brief on the Galaxy S25
