How to auto-reject phone calls on the LG G3
Whether you're trying to reject all phone calls or just selected numbers, on the LG G3 it's a simple process to achieve your desired results. We've already looked at how to reject an incoming call with a custom message to the caller, now let's take it a little further by telling the phone to auto-reject based on certain parameters.
First things first you need to navigate your way to the necessary menu:
- Head into "Settings"
- Scroll down until you see "Call"
- You're looking for "Call reject," so hit that and you're in the right place
You'll be presented with two options; "Call reject mode" and "Reject calls from."
- Call reject mode: Three options to choose from, turn it off completely, reject calls on list or reject all calls. The second option will tie in with the below while the third option is what you should choose if you don't want to be bothered by anyone.
- Reject calls from: Here you can add numbers that you want to auto-reject either from your contacts, your recent call logs or just by manually entering a number. If you want to reject all calls from private numbers tick the checkbox at the top of the screen.
And that's all there is to it. With the combination of options above you can tailor just who you want your G3 to auto-reject.
For more, see our LG G3 help page, and swing by our G3 forums!
Be an expert in 5 minutes
