Here's how to score this powerful 60W USB-C Wall Charger for less than $12 at Amazon
Make sure you're charging your electronics and laptop as efficiently as possible with the Choetech 60W USB-C Wall Charger. Featuring Power Delivery 3.0, it's designed to offer an optimal charge based on what's plugged in to keep your devices safe from overcharging, over-voltage, and more. While normally sold for up to $33, you can pick one up today for as low as $11.67 at Amazon when you clip the on-page coupon and then use promo code KFD272NY during checkout. That low price also takes into account an automatic discount that's exclusively available for Prime members, though the non-Prime price of $12.79 isn't bad either.
Choetech 100W USB-C Cable
$4.94 $15.97 Save $11
Reach faster charging speeds with this 6-foot USB-C cable which supports up to 100W. Being Thunderbolt 3-compatible, it also features 10Gbps data transfers, 4K video, and more. Clip the on-page coupon and enter the below code for the full savings.
Choetech Wireless Charging Bundle (2-pack)
$14.54 $22.99 Save $8
Choetech is offering an extra $5 off a two-pack of its popular wireless chargers right now. You'll score a 10W wireless charging stand and a wireless charging pad. Just clip the on-page coupon to score the additional savings.
Choetech USB-C to HDMI Cable
$4.23 $18.70 Save $14
This HDMI cable by Choetech was designed to be more versatile than traditional models. It has a USB-C connector on one end so you can plug it into your phone or USB-C computer without needing an adapter. Use the coupon to save.
Choetech 5-in-1 USB-C Hub
$6.98 $19.99 Save $13
Choetech's 5-in-1 USB-C Hub is equipped with two USB 3.0 ports, an HDMI port that supports 4K video, and an SD/microSD card reader. Just clip the coupon on its product page and use the following code at checkout to score this low price.
Choetech car air vent wireless charger mount
$6.99 $11.98 Save $5
This USB-C wall charger features a single USB-C port with a maximum output of 60W. Devices compatible with Power Delivery 3.0 will charge even faster than others, though all devices should charge safely thanks to the charger's built-in smart identification chip which can identify the voltage and current that your device requires to charge properly.
You'll be able to power up laptops such as the 13-inch MacBook Pro fully in just two hours. You could also use it with devices such as the Nintendo Switch. It has a foldable plug, is compact, and easy to pack in nearly any bag. Just make sure you have a USB-C cable to go along with it, or add one to your cart before checking out if you don't. This guide to the best USB-C cables has a good list to choose from.
Choetech includes an 18-month warranty with this charger's purchase. Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. Having a membership could also score you an extra discount on today's purchase, so why not start a free 30-day trial and see how it is? You'll snag free two-day shipping with no order minimum, along with access to the Prime Video streaming service, other exclusive members-only discounts, and more.
