Green Throttle expands Atlas Controller support to any device running ICS and above
Green Throttle, a start-up focused on bringing quality console-level controllers to Android devices, is announcing wider device compatibility of its app and Atlas Controller. The controller can now be used on any Android device running ICS (4.0.3) or later, although Green Throttle recommends you use a device with video-out support in order to play on a larger screen. After its installed, Green Throttle Arena lets you play games with up to four players on your Android device with a much better experience than using a touch screen.
The app is free, but the Atlas Controller itself will set you back $39.95 stand-alone, or $49.95 with a bundled Micro USB charger and HDMI cable. If you want to play with a friend, a two controller bundle runs $89.99. If you'd like to check them out for yourself, you can grab the app from the Play Store link above, and see more about the controller and technology at the link below.
More: Green Throttle
Be an expert in 5 minutes
Andrew was an Executive Editor, U.S. at Android Central between 2012 and 2020.
