Grab the WD Elements 8TB hard drive for nearly $20 off
The WD Elements 8TB USB 3.0 desktop hard drive is down to $121.09 at B&H. We have only seen this hard drive drop this low once before, and that was back in August. It normally sells for around $140, which is the price you'll find it at other retailers like Amazon.
WD easystore 14TB External USB 3.0 Hard Drive
$219.99 $300.00 Save $80
You're actually going to look for ways to fill up this drive. Uses USB 3.0 interface for speedy data transfer and it's backwards compatible with 2.0. Works on PC and Mac but needs reformat for the latter. Comes with 2-year warranty.
WD My Passport 1TB USB-C portable solid state drive
$139.99 $150.00 Save $10
Has a transfer rate of up to 1,050 MB/s thanks to USB-C and USB 3.2 Gen 2 tech. Includes 256-bit AES hardware encryption for data protection. Drop resistant up to 6.5 feet. Has good backup software for protecting your data. Works with Mac and PC.
WD Easystore 16GB external desktop hard drive
$259.99 $350.00 Save $90
How much data can you store? This drive has the space for it! Uses USB 3.0 interface for speedy data transfer and it's backwards compatible with 2.0. Works on PC and Mac but needs reformat for the latter. Comes with 2-year warranty.
WD My Passport 500GB external USB-C portable solid state drive
$79.99 $120.00 Save $40
Includes blazing-fast NVMe tech for read/write speeds up to 1,050 MB/s and 1,000 MB/s respectively. Has 256-bit AES hardware encryption to keep your data safe. Resists shocks and drops so it can endure some punishment. Has a 5-year warranty.
WD Easystore 2TB USB 3.0 external portable hard drive
$59.99 $100.00 Save $40
Connects via USB 3.0 for an easy-to-use interface that has data transfer speeds up to 5 Gbps and is backwards compatible with USB 2.0. Set up automatic backup options or manage your drive with WD's free software. Works with PC and Mac.
The desktop drive is plug-and-play so is super simple to use. It's equipped with USB 3.0, so all you have to do is connect it and begin transferring whatever you want. It is compatible with Windows and Mac, but you'll need to reformat it for the latter. It comes with a two-year warranty. Users give this series 4.4 stars based on 1,293 reviews at Amazon.
