Grab two Google Nest Mini smart speakers and two smart plugs for just $45 total
Head on over to BuyDig and you can get two of the Google Nest Mini 2nd-generation smart speakers plus two Deco Gear smart plugs for just $45 total when you use the promo code PCG10 during checkout. The smart plugs are $28 on their own, and the speakers would cost you $70 without the code. So you're saving $53, which is more than the cost of the deal itself. The speakers are going for around $35 individually at most retailers like Target, so paying just $10 more gets you a second speaker along with the smart plugs. Not a bad way to save today.
Google Pixel 3 and Pixel 3 XL
$189.95 $799.00 Save $609
$189.99 $799.00 Save $609
$216.99 $799.00 Save $582
$243.99 $799.00 Save $555
Google Nest smart programmable thermostat snow
$87.99 $130.00 Save $42
Smart enough to turn itself down when you leave so it doesn't waste energy on an empty home. Create an energy-efficient schedule in your smartphone app. Can even provide advice to help you save more money later.
The Nest Mini is a 2nd-generation speaker, an upgrade over the original Google Home Mini. You can read more about it in our review. We gave it 4.5 stars out of 5 and a Recommended badge. The review said "it's a product that's easy to purchase on a whim" and added "Whether you're getting into the Assistant speaker market for the first time, or this is your tenth speaker, the Nest Mini is a great small speaker... It brings the new Assistant, and the machine learning chip should allow conversations with Assistant flow faster."
The Nest Mini is much better than the original, especially when it comes to sound. The bass is 40% stronger than the first generation, and it's designed to not only play sound in all the rooms of your house but to be heard despite the noise. With far field voice recognition, you'll be able to access your Google Assistant from anywhere in the room. Ask your new speaker to stream music, share the latest news, play podcasts, and more.
Not only that, but the speaker is "thoughtfully designed" with a durable fabric top made from 100% recycled plastic. It also has an integrated wall mount that makes it easy to place around your home and LEDs that light up to show you volume controls as you approach.
