Grab RAVPower's 3-port USB wall charger for over half off at Amazon
The RAVPower 30W 3-port USB wall charger is down to just $7.50 when you combine the $2 off on-page coupon with the code HVVQHGPI on Amazon. That's a huge chunk off its regular price considering it's going for $16 without either code and more regularly sells for around $13.
RAVPower 65W 4-port USB Desktop Charging Station
$34.99 $49.99 Save $15
Keep USB ports close by with this 65W USB Desktop Charging Station by RAVPower. It's equipped with two USB-C ports as well as two USB-A ports. Clip the coupon on its product page and use the following code at checkout to save $15.
RAVPower 10000mAh portable charger dual USB power bank
$9.99 $15.00 Save $5
The ultra slim power bank is only 15mm deep, so it's extremely portable. The battery size of 10000mAh is enough for a full charge of even the largest phones. Can charge two devices at once and has built-in safety features to protect them all.
RAVPower 61W Power Delivery 3.0 USB-C 2-port wall charger
$23.39 $30.00 Save $7
Has 61W output with Power Delivery 3.0. Can charge a MacBook in 2.1 hours. Can detect what's plugged in and deliver fastest possible speeds. Wants to be portable with slim, compact design and foldable pins. Includes built-in safeguards.
RAVPower 48W USB-C Car Charger with Power Delivery 3.0 and Quick Charge 3.0
$14.99 $19.99 Save $5
RAVPower's fast dual-port car charger features a 30W Power Delivery 3.0 USB-C port along with an 18W Quick Charge 3.0 USB-A port. Clip its on-page coupon to snag this deal.
RAVPower 25000mAh solar phone charger outdoor portable charger
$21.99 $46.00 Save $24
Use sunlight to recharge this charger's batteries or plug it in via micro USB or USB-C. The 25000mAh capacity is enough to keep all your devices going outdoors. Includes an LED flashlight and SOS mode for emergencies. Waterproof and dust proof.
The wall charger has three USB-A ports with an output of 6a total. You can charge three devices at once and spread the output around with 2.4a max per port. Get your smartphone, tablet, and whatever else topped off all at the same time. The charger is designed with safety in mind, as well. It has multiple points of protection to ensure your devices won't get damaged in any way. Don't worry about things like overheating, over charging or short circuiting while plugged in.
The design also has rubberized sides and an enhanced grip. It won't slip out of your hands or slide around when it's not plugged in. Plus the grip makes it easy to plug and unplug different devices in a hurry. Fold in the pins and shove the charger in your backpack as it's easy to travel with. The 100V-240V input makes this charger great for travel, too, because that means it can be used around the world.
The charger comes with an 18-month warranty, and users give it 3.9 stars out of 5 based on 392 reviews.
Pair this charger with a battery pack like the one on sale from EasyAcc today. The large capacity power bank has dual recharging inputs, which the RAVPower can handle. That's a great pairing for keeping all your gear charged up even while you're out and about. Plus, it's on sale just like the charger is. Grab the portable battery for $19 and this charger for $7.50 so you're saving big on money and power.
Be an expert in 5 minutes
