Grab Pelican's compact LED flashlight for a low price of $15 today only
As part of B&H's DealZone today, you can grab the Pelican 3rd-Generation 1910B LED flashlight in Blue or Red for $14.95. The black version is going for $24, which is what this light normally goes for. You can find them at a similar price or even more at other retailers like Amazon. The deal price expires after today, though.
Pelican 1650 Case With Foam (Black)
$225.95 $374.00 Save $148
Pelican 1510 case with padded dividers
$199.95 $237.95 Save $38
Pelican 1620 Case With Foam (Black)
$230.00 $392.95 Save $163
$245.96 $299.95 Save $54
Pelican 1660 Case With Foam (Black)
$295.00 $378.19 Save $83
Pelican is a company known for making high-quality products. These flashlights come with limited lifetime warranties, which just shows Pelican has confidence in their durability. And they are built to last with aluminum housing, a polycarbonate front lens, and an O-ring that's waterproof. They are very energy efficient, too, since they use just one AAA battery. Need a place to keep it when you're not using it but might need it? The carbon-steel pocket clip helps you secure it to your pocket or your belt.
The flashlight has two brightness modes you can pick between with one giving an illumination of 21 lumens and the other giving off 106 lumens. Use the diamond-knurled tailcap click-type switch to tap between a constant-on and a momentary activation mode for the light.
The waterproof O-ring helps with the flashlight's IPX7 rating, which means it is water resistance and capable of handling submergence up to 3.3 feet.
