Grab a pair of noise-cancelling BackBeat GO 810 Wireless Headphones at over 50% off
Having a pair of comfortable headphones to block out the noise around you can be super important when you're trying to focus on what you're listening to rather than everything that's going on around you. Luckily, Amazon has the noise-cancelling Plantronics BackBeat GO 810 Wireless Headphones on sale today in Graphite Black for just $70.38 while supplies last. That saves you over 50% off their usual cost of $150 and takes it down to a new low price. Two other styles of these headphones are currently down to $89.99 which is a pretty great deal as well.
The Plantronics BackBeat Go 810 are over-ear wireless headphones which are equipped with 40mm drivers and an integrated battery which can last for up to 28 hours while using Bluetooth. With Active Noise-Cancelling enabled, they last for about 22 hours. You can also choose to plug them in to a device and not worry about the battery life over Bluetooth at all.
A built-in microphone allows you to take calls hands-free over Bluetooth while your phone stays in your pocket or across the room. However, it does come in handy to use your phone alongside these headphones as you can download the free BackBeat FIT app to customize the sound with EQ presets, noise-cancellation settings, and more.
Plantronics designed these headphones to be comfortable for hours on end, with memory foam ear cushions and an adjustable headband to help them fit nearly anyone.
Shipping at Amazon is free on orders totaling $25 or more, but you could receive your order even faster with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, along with access to the Prime Video streaming service, exclusive members-only discounts, and more.
Be an expert in 5 minutes
