Grab Jabra's Elite Active 75t true wireless earbuds down to their lowest price at $112 refurbished
If you head over to eBay right now you can get the Jabra Elite Active 75t true wireless earbuds for $111.99 refurbished when you use the code PICK2SAVE. The code should even be present right above the promo code window so all you have to do is click. These refurbs come straight from Jabra's official store so you know it's quality. The deal includes free shipping, too.
These sell for $200 new at Best Buy. We shared a deal earlier in May that featured these refurbished earbuds dropping $140 through the same eBay page, but this new code brings them down to a low price we have never seen before.
You can also get the regular Jabra Elite 75t for just $99.99 through the same Jabra refurb store and using the same code during checkout. Saves you a bit of money, especially if you don't plan to use these earbuds for your workouts. Check out how the Elite 75t compare to the Elite Active 75t, and decide for yourself which one you should go for.
The Elite Active 75t earbuds are powerful, feature-rich earbuds. They have Bluetooth 5.0 technology, which improves power efficiency and keeps your audio from getting interupted. The earbuds are also extremely durable with an IP57 rating that makes them resistant to dust and water, including sweat. That's why they're called "Active," after all. Take these earbuds to the gym and you'll be able to use them through any workout.
You won't have to worry about the battery life either. The earbuds last for up to 7.5 hours on a single charge, and they come with a charging case that can give you up to 28 hours total before you ever have to plug in. The earbuds will also fit securely in your ears so you don't have to worry about them falling out while you're running or walking or doing other workouts.
Use the earbud controls to play or pause your music, answer and end phone calls, switch tracks, and more. The earbuds use a stereo design with 6mm drivers that provide powerful sound. The stereo design means you can use either the right earbud by itself or both earbuds, but the left one depends on the right one so it can't be used individually.
