Grab great noise-cancelling headphones, the Bose 700, for $237 refurbished
Bose 700 Anc Ar
Bose 700 Anc Ar
Oftentimes the best gear is priced a little too high to be accessible, and that's unfortunate because everyone should get a chance to experience really great active noise-cancelling and other tech like that. Right now you can get the Bose 700 noise-cancelling Bluetooth headphones for just $237 through the Bose eBay store. The headphones are in a refurbished condition, but usually even refurbished Bose only sells them for around $279. If you add these to your cart right now, you should see the price automatically discounted by another chunk of change, bringing them down to the lowest we've ever seen. That's much better than the regular $379 price for a new pair you can find at Amazon.
The Bose 700 separate themselves from Bose's other headphones by providing some of the best noise-cancelling tech you'll ever hear... or not hear. Depending on what you want. You'll get 11 different levels of adjustable noise-cancelling to assist you in finding the perfect balance between your sound and the environment around you. If you just purely want the music, shut down all ambient noise. Need to hear a little bit of the sounds around you because you're at the office or in a public place? You can do that, too. Tune out the world or make yourself available. It's all up to you.
Not only that, but you can also use the controls built into the headphones to adjust all its other aspects, too. You can even access the voice assistant on your phone if you've connected both devices. It works with Amazon Alexa and Google Assistant with just the press of a button. Ask about the weather or the news, gain access to even more music streaming from all your favorite platforms, and more.
You can get up to 20 hours of battery life on a single charge, and it only takes about 2.5 hours to fully recharge. Plus, with the rapid charge tech you can get 3.5 hours after just 15 minutes for when you're really in a pinch.
