Grab a Eufy RoboVac 30C robot vacuum, a smart speaker, and two smart bulbs all for $162
This deal is a little more complicated than your average way to save. First, go to this product page featuring the Eufy Genie smart speaker and two Lumos smart bulbs. Clip the 30% off on-page coupon. That'll take $18 off the price at checkout.
Then add the Eufy RoboVac 30C self-charging robot vacuum cleaner to your cart. During checkout, with both items in your cart, use the code EUFYGENIE to take another huge chunk of $59.99 off the price. This will bring the final total down to $161.56. That's about $10 better than any deal we've seen on the RoboVac 30C by itself and still includes the smart bulbs and speaker to do with as you please.
Eufy cordless stick vacuums and robot vacuum cleaners
As low as $140
Choose from a cordless stick vacuum or a robot vacuum. The cordless vac includes 120AW suction power for 8 minutes or 25 minutes in standard mode. Helpful for getting into tight spaces. The robot has 1300Pa suction and lasts up to 100 minutes.
Eufy Security Wi-Fi 2K resolution video doorbell
$119.99 $160.00 Save $40
You'll get a wireless chime you can use somewhere else in the house to hear the door wherever you are. Has a 2K resolution image with advanced HDR and distortion correction. Includes two-way audio, motion detection, and smart alerts.
Eufy RoboVac 15C Max Wi-Fi connected robot vacuum cleaner
$175.99 $ Save $
Comes with super strong 2000Pa suction so it can pick up even stubborn dirt. BoostIQ feature will even boost the suction when you need it. Lasts for up to 100 minutes. Use the EufyHome app and connect it to your smart home for more control.
Eufy Spaceview Security by Anker baby monitor camera bundle
$129.99 $170.00 Save $40
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Can pan 330-degrees and tilt 110-degrees so you can see the whole room. Get instant alerts. Has a range up to 1,000 feet.
Eufy Security SpaceView 720p video baby monitor with night vision
$109.99 $160.00 Save $50
Has a large 5-inch 720p display for a sharp picture. Let's you see everything your little troublemaker is doing. Includes a wide-angle lens for when your baby starts moving around more. Get instant alerts. Has a range up to 1,000 feet in open area.
The smart speaker and Lumos smart bulbs from Eufy can easy be the starter kit for your smart home. The Genie is sort of like a budget Echo Dot in that it has its own built-in 2W speaker and access to Amazon Alexa. You can stream music or use your voice to control your home. Use the app to control it from anywhere. The two smart bulbs are white but tunable, and they come with an 18-month warranty.
The RoboVac 30C is also smart and can connect to this new smart home ecosystem you're building. It also uses the same EufyHome app so you can program it and pair it. Use Amazon Alexa or Google Assistant to control it with voice commands.
Eufy's RoboVac 30C has a tiny 2.85-inch body so it's small enough to fit under a lot of furniture. It comes with boundary strips, too, so you can keep it out of areas you don't want it to go. The RoboVac has BoostIQ technology to automatically increase suction power when that extra strength is needed, and you'll get up to 100 minutes of constant suction with little noise pollution.
Users give the RoboVac 30C 4.4 stars out of 5 based on more than 3,100 reviews.
