Grab Anker's dual-port USB-C wall adapter while it's down to $28
The Anker PowerPort Atom III 60W dual-port USB-C wall adapter is down to $28.15 on Amazon. This adapter goes for around $43 from Amazon and usually sells for that much through AnkerDirect, but today's price matches its all-time low. We have seen it drop to this price a few times over the last week, but that's to be expected with the holiday shopping season underway. Grab it while you can before the price goes back up and stays there. The black version is also discounted today, down to $30.99. That's not quite as low but possibly worth a couple extra bucks if you prefer the color.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
Latest Videos From
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The PowerPort Atom III has one USB-C port and one USB-A port, which means it's pretty much compatible with everything. Charge Android phones, Apple phones, laptops, handheld consoles, tablets, or whatever. The USB-C port has 45W power output and the other port has 15W, which makes the USB-C port powerful enough to charge even a laptop or the Nintendo Switch. You can use both of them at the same time, too.
Anker's PowerIQ technology can detect what's being plugged in and provide it the fastest possible charge. The PowerIQ 3.0 tech in the USB-C port is Anker's most advanced version yet. The other port uses PowerIQ 2.0, which still helps provide some high-speed charging.
The design is 15% smaller than previous generations and uses gallium nitride to achieve that without sacrificing the power output in the process. The wall charger comes with Anker's 18-month warranty.
You will need cables to connect your devices to this adapter. Right now you can get 20% off these USB-C to USB-C cables from Anker. Or get a 6-foot USB-C to Lightning cable for $17. This 3-foot Lightning to USB-A cable from AmazonBasics is down to just $9.09 at the moment.
