Grab an Anker wireless charging pad and stand bundled together for just $24
Until they invent a way for the very air to carry a wireless charge and just continuously juice up all our electronics as we walk around, you are still going to need pads and stands around your home for you to rest your wireless charging phones upon. Anker's got you covered with that today. Grab this wireless charging bundle that includes a PowerWave pad and stand on sale for just $23.99 with code M252411D on Amazon. This bundle actually sells for $35 most of the time, but it's down to just $26 right now and the code knocks off another couple of bucks. That brings it down to one of the best prices we've ever seen.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Keep the angled stand on your nightstand so you can binge some cartoons before bed while the phone charges. Keep the pad on your desk so you won't be distracted by all the notifications while your phone gets recharged. Or keep them both together so you and your partner can charge together. Partners who charge together, communicate more. Cause their phones work.
Both devices work with Android and iOS mobile devices. As long as it has Qi-certified wireless charging, you'll get something out of Anker's bundle. Apple iPhones get 5W and Samsung Galaxy phones get 10W high-speed charging assuming you're using a wall adapter that's powerful enough.
Both chargers have built-in safeguards. The safety features include protection from overvoltage, temperature control, foreign object detection, and more.
You will want to get a solid wall adapter since this bundle doesn't come with one. You'll really need one for each device so grab two if its necessary. The Anker 18W USB wall charger will ensure your wireless pad or stand is giving you the fastest charge possible.
The bundle includes two micro USB cables and an 18-month warranty from Anker.
