Grab an Anker wireless charger, power bank, and more for up to 36% off today
Running low on charging gear? Have you added a new phone or tablet to your household that needs some extra juice? Just want to complete the rounds of putting a wireless charger in every room of the house? Whatever you might need a wireless charger for, today is your day to grab one because Anker has several products on sale on Amazon in a one-day sale that is taking up to 36% off the price of some gear.
Anker's PowerWave pad includes a space for wireless charging and for your Apple Watch to charge, and it's down to under $30 from a street price of $60. Get $10 off a wireless charging pad, save $8 on a 5-port Quick Charge 3.0 wall charger, and more.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The deals include Anker's Quick Charge 3.0 5-port wall charger on sale for $21.89 from a regular price around $30. This is a match for its lowest price ever, a price we've only seen it hit a couple of times in the past. And a wall charger like this is a great place to start because you'll need to plug in some of these other Anker devices into a device you know will give you the best speeds, and there's nothing faster than Quick Charge 3.0.
Grab the Anker PowerWave Alloy Pad on sale for $19.99 from $30. It's a simple device that's powered by USB-C and allows you to wirelessly charge your iPhone, Android smartphone, and more. It can deliver up to 15W max charging speeds with up to 7.5W charging for the iPhone.
If you have a work phone and a home phone or you're sharing a nightstand, you can get Anker's PowerWave Dual Pad, a wireless charging pad that includes space for two smartphones. It's down to $29.59 at Amazon, which is $10 off its regular price. The only other time the pad has dropped this low directly was over Black Friday. You can charge two devices at once and still get up to 10W charging for Samsung phones and 7.5W charging for the iPhone.
Both charging pads can work with a phone's case as long as it's less than 5mm case. Plus, all Anker products come with an 18-month warranty.
