Grab this $18 smart LED light strip kit to add some ambiance around your home at a discount
Gosund Smart
Gosund Smart
Making sure your home is ready for the big game this weekend is no small feat. Thankfully, there are several deals to improve your game day party like this Gosund Smart LED Strip Lighting Kit on sale at Amazon for only $18.19. You'll just need to use promo code AA25ONXT during checkout to snag the kit at this low price. That saves you an instant 30% off its usual cost of $26, and also brings this new kit lower than it's ever reached without a code before.
Gosund 4-pack smart plug upgraded
$13.49 $27.00 Save $14
Clip the on-page coupon and use the code. Compatible with Amazon Alexa and Google Assistant so you can control whatever is plugged in with voice commands. Or just use the Gosund app to control them from your phone, set up groups, timers, and more.
Smart Plug, Gosund Mini WiFi Outlet Works with Alexa, Google Home, No Hub Required, Remote Control Your Home Appliances from Anywhere, ETL Certified,Only Supports 2.4GHz Network(4 Pieces)
$22.99 $26.99 Save $4
$20.39 $26.99 Save $7
$23.99 $26.99 Save $3
$25.99 $27.99 Save $2
With Gosund's smart backlighting kit, you'll be able to control the lights using an app on your smartphone or tablet. That way there's never any risk of losing a remote or hassle of having to change out batteries. It's even capable of being voice controlled using a device with Amazon Alexa or Google Assistant, such as the Echo Dot. Once set up, you'll never have to get out from under the covers to turn the lights off before bed ever again; just use your phone or ask Alexa or Google Assistant for help.
This LED light strip measures 16.4 feet long, though it can be cut down to size if you're in need of a shorter length. With the 3M adhesive backing, it's simple to install this strip just about anywhere, from behind your TV or computer desk to in the kitchen, garage, and more. The strip is waterproof as well and can be powered using either a USB port or a wall adapter.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum. You'll also gain access to benefits such as the Prime Video streaming service, exclusive members-only discounts, and much more.
