Get wireless charging and USB-C with Aukey's true wireless earbuds on sale for $51
The Aukey T10S true wireless earbuds are down to $51.29 on Amazon when you clip the 20% off on-page coupon and use the code R5EQKVB4 during checkout. Use both discounts for the best possible savings, which brings these earbuds down from a regular $90 price. That is a huge discount we have never seen on these before. They don't even drop below $90 directly most of the time.
Aukey 9-in-2 USB-C hub for MacBook Pro or MacBook Air
$41.99 $60.00 Save $18
Unique design requires two USB-C ports back-to-back, which is why this is particularly suited for a MacBook that has such a configuration. Turn those two ports into nine tools including HDMI, Thunderbolt 3, and a 100W Power Delivery charging port.
Aukey Sports true wireless earbuds with earhooks
$27.49 $50.00 Save $23
Include powerful 12mm drivers for high-fidelity audio. The ear hook design won't let go even when you're at the gym. They have IPX8 water resistance, which is full waterproof support. The battery life lasts up to 35 hours with the included case.
Aukey Bluetooth true wireless earbuds
Up to 30% off
All the prices are discounted and the costs vary between $21 and $49. All you have to decide is which one looks best to you and has the features you need (like the Sports earbuds that stay on even while you run). Choose from black, white, and pink.
Aukey KM-G6 LED Mechanical Gaming Keyboard
$27.99 $44.99 Save $17
This well-reviewed keyboard features 104 anti-ghosting keys, nine preset lighting effects, and even comes with a two-year warranty. Today's deal at Amazon saves you $12 off its regular price while supplies last!
$25.24 $50.00 Save $25
The Aukey earbuds have dynamic drivers and graphene diaphragms so you get a ton of extra depth, full sound, and a wider soundstage. Considering how little you're paying, you're going to be blown away by the audio quality. It's something you'd expect from earbuds that cost three times as much.
You'll also get super fast USB-C charging, and the charging case is Qi wireless charging compatible. So if you have a charging pad like this, you can just put the case on top without needing to plug in any cables. That's a super convenient way to charge.
These are IPX5 rated earbuds. That means they resist water damage, so you can take them outside in the rain or to the gym for your next workout. Don't worry about incidental splashes or anything like that. The battery life lasts up to 7 hours, and you'll get an extra 24 hours using the charging case before you ever have to recharge.
The side of the earbuds have touch-sensitive controls. You can tap or press to adjust the volume, change music tracks, play or pause, or even access your mobile device's built-in voice assistant like Siri or Google Assistant.
Find the best possible fit for you with these earbuds. You'll definitely want them to sit as securely as possible in your ears if you plan to use them while you workout. They are lightweight earbuds and come with three sizes of ear tips and in-ear ear hooks so you can get a custom fit for your ears.
