Get help for holiday messes with the Ecovacs Deebot 901 robot vacuum down to $191
Between Thanksgiving meals, Christmas presents, and Black Friday shopping, you're going to have a whole lot of messes around the house before the new year. Get some help with that with a robot vacuum cleaner companion to pick up the dirt and dust. The Ecovacs Deebot 901 can be yours for just $191.09 with the code 19CYBER15 through Google Shopping. The deal comes from NNC Deals who are already discounting the price of the robot vacuum to $210 compared to the same model going for $250 from the same seller on Amazon.
The coupon code can stack with other items and save you up to $100 if you want to keep shopping. Keep in mind this is a third party and the shipping will not be super speedy. When checking out, my shipping estimate was for Dec. 9. It is free though, so there's that.
The Deebot 901 is the sort of robot vacuum where once you've set it up initially, you won't have to bother it much again after that. It uses Smart Navi technology to map your home and learn the floor it's cleaning. This keeps it from getting stuck on obstacles and makes the cleaning path it takes more efficient. It also gives you some control over how you want the vacuum to clean since you can customize the map it creates.
The vacuum can transition between multiple floor types, too. Let it clean your hard floors and your carpet at once. It has interchangeable suction plates to help make cleaning different floor types even better. Use the Edge or Spot mode to change the areas the Deebot 901 concentrates on.
Once you connect the vacuum to your Wi-Fi, it will be able to update itself over the air automatically. Plus, it has voice reporting that can let you know of its progress in real time. You can control the vacuum via the free app or connect it to your smart home for voice control. The battery lasts up to 90 minutes.
