Get a head start on spring cleaning with $70 off this popular robot vacuum
Ilife A9 Smart Robot Vacuum Hero
The prospect of being stuck inside because of Coronavirus for the foreseeable might not fill you with joy, but you might take the opportunity to get an early start on your spring cleaning. Having a smart robot vacuum cleaner like the ILIFE A9 helps you automate one aspect of your cleaning thanks to its built-in smarts. It automatically maps out your home and cleans all by itself, and you can even schedule future cleanings using your phone. Thanks to a sale at Amazon, it's now available for nearly its lowest price in history. At just $179.99, you'll be grabbing it at its best-ever price while saving $70 off its usual cost.
iLife Shinebot W400s mopping robot
$172.49 $230.00 Save $58
Mops in four stages: sprays your hard floor with clean water, scrubs with a microfiber roller, removes the dirty water, then wipes off any residues with a rubber scraper. Has multiple cleaning modes and can clean up to 600 square feet.
ILIFE A9 Robot Vacuum Cleaner
$159.99 $229.99 Save $70
This smart robot vacuum cleaner automatically maps and navigates your home to keep it clean. Control it with the free app or even with your voice and a smart home assistant like Alexa or Google Assistant. Clip the on-page coupon to save.
ILIFE V8s Robot Vacuum Cleaner
$169.99 $249.99 Save $80
ILIFE A4s Robot Vacuum
$149.99 $179.99 Save $30
$179.99 $299.99 Save $120
Unlike some robot vacuums, the ILIFE A9 will not just run around randomly cleaning up your floors. It uses sophisticated mapping and navigation technology and cleans in a methodical back-and-forth pattern. It won't repeatedly go over the same spots and it won't miss areas. Plus, the vacuum has 14 smart sensors that help it to clean along furniture and walls and climb over low piles of carpet or whatever. The vacuum is only three inches tall, too, so it can safely go underneath some pieces of furniture like your bed. The sensors keep it from falling down the stairs or getting stuck on obstacles.
You won't have a hard time cleaning out the dustbin or doing maintenance either thanks to the upgraded CyclonePower cleaning system. The technology also helps extend the life of the high-efficiency filters. The A9 is also designed to automatically return to its charging station when it's low on battery or done cleaning for the day.
The A9 comes with an Electrowall device. It's a gadget you can use to create virtual barriers for your robot vacuum. It won't cross the lines you set in place so you can keep the vacuum from going places it doesn't belong. Download the companion app on iOS or Android. Use it to operate your new robot vacuum. Set schedules, select cleaning modes, follow the A9's progress, and more. Makes controlling your new tool a breeze.
Users give the A9 4.1 stars out of 5 based on over 230 reviews. If it's not the right vac for you, check out this guide to the best smart robot vacuums for some alternatives.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
