Get Extreme performance with SanDisk's 400GB microSD card at one of its best prices
You are now subscribed
Your newsletter sign-up was successful
Need a new storage solution? The SanDisk Extreme 400GB microSD card with an included adapter is down to $85.87 on Amazon. This well-rated microSD card has sold for up to $150 in the past, and it typically hovers around $100. Today's deal is a match of the best we've seen, and it brings the card down to a price we haven't seen since early summer. There's no telling when it'll disappear or when it might make a return once expired.
This microSD card has read speeds up to 160 MB/s and write speeds up to 90 MB/s. You'll be able to transfer even high-resolution images and 4K videos without much delay, and the card is fast enough to keep up even with burst shooting. This is a UHS Class 3 card (Ultra High Speed) with an A2 rating. Most cards we post deals on are rated A1 and Class 10. This one is better in both regards and is generally reserved for professionals. The card is designed to resist extreme temperatures, water, shock, and X-rays. It has 4.5 out of stars based on over 2,000 customer reviews. Many devices cannot handle a microSD card this large, so make sure your device is compatible before purchasing. If 400GB is a bit too much for your device, other iterations of this card are on sale today as well, so definitely check those out.
While you're shopping for extreme storage, you might want to check out this discounted SanDisk Extreme Pro 2TB Portable SSD. It's not a product for everyone. You might really only need it if you're into photography or videography. However, today's price saves you $100 off the normal cost, and it's another great deal to think about if you need to store some bigger files.
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
