Get Extreme performance with SanDisk's 256GB microSD card at its best-ever price
Need a new storage solution? The SanDisk Extreme 256GB microSD card is down to just $40.39 on Amazon. This well-rated microSD card has sold for up to $100 in the past, though it typically hovers around $53 these days. Today's deal is the best we've ever seen for this card, marking a new all-time low price on it. You've only got until the end of the day (or until sold out) to make the most of it though as it is a part of a wider one-day sale on PCs and accessories at Amazon.
SanDisk Extreme 1TB portable USB-C NVMe solid state drive
$149.99 $240.00 Save $90
Includes a USB-C 3.2 Gen 2 interface for wide compatibility with USB-C devices like computers and smartphones. Has read/write speeds up to 1050 MB/s and 1000 MB/s thanks to the fast NVMe tech. Also IP55 rated for dust and water resistance.
SanDisk 256GB microSDXC memory card
$50.60 $55.00 Save $4
This is Amazon price matching Best Buy. The 256GB card works with any system that can read it and is officially licensed for the Nintendo Switch and Switch Lite. Has read and write speeds up to 100 MB/s and 90 MB/s. Limited lifetime warranty.
SanDisk Extreme Pro 2TB USB-C portable solid state drive
$309.99 $350.00 Save $40
The SSD has powerful NVMe technology with read/write speeds up to 2,000 MB/s. Of course it works with devices not quite capable of that but you won't get speeds as fast either. It comes with a 5-year warranty from SanDisk.
SanDisk Extreme 1TB external USB-C portable solid state drive
$124.99 $140.00 Save $15
Has a 1TB storage capacity and connects easily via USB-C. Even while on the go, you'll get super fast transfer speeds with read speeds up to 550MB/s. The enclosure itself is rugged and resistant to water, dust, and drops. Works with PC and Mac.
SanDisk 1TB Extreme Portable SSD
$155.58 $163.75 Save $8
This microSD card has read speeds up to 160 MB/s and write speeds up to 90 MB/s. You'll be able to transfer even high-resolution images and 4K videos without much delay, and the card is fast enough to keep up even with burst shooting. This is a UHS Class 3 card (Ultra High Speed) with an A2 rating. Most cards we post deals on are rated A1 and Class 10. This one is better in both regards and is generally reserved for professionals. The card is designed to resist extreme temperatures, water, shock, and X-rays. It has 4.5 out of stars based on over 2,500 customer reviews. Some devices cannot handle a microSD card this large, so make sure your device is compatible before purchasing. If 256GB is a bit too much for your device, other iterations of this card are available, so definitely check those out.
If it's storage you're after, today's sale at Amazon is for you with discounted flash drives, hard drives, and SSDs aplenty. There are also a plethora of other PC-related peripherals like Wi-Fi range extenders, NAS systems, monitors, gaming mice, and more. Just be sure to get any orders in by the end of the day.
