Get Anker's Soundcore Liberty Air true wireless earbuds at their best price yet at Amazon
Wireless earbuds are the future, and you don't have to spend nearly $200 on a pair of AirPods to snag a pair worth your time. Anker's Soundcore Liberty Air True Wireless Earphones made their debut at the end of last year at half the price of Apple's AirPods; today, you can save an additional $23 on their purchase and pick them up at Amazon for just $56. The discount is thanks to a direct price drop to $59.99 plus a further $4 discount provided by Amazon. This is the first time we've seen these earbuds drop this low since their release, though the savings only apply to the white version at present with the black model still at $79.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The Liberty Air offer 5 hours of playback per charge, and the compact carrying case actually can provide an additional 15 hours of usage time. You can use one headphone at a time, or both, and the noise-cancelling mic makes for crystal clear calls. There are integrated touch controls on the earbuds for controlling music playback, answering calls or summoning your phone's voice assistant. The earbuds are also IPX5 rated to ensure they don't get ruined while you work out or if you get caught in the rain.
In our review, the Liberty Air garnered a rating of 4 out of 5 stars with nods to their great sound quality and overall value. Existing owners rate them similarly with an average rating of 3.8 stars from almost 500 reviews at Amazon.
The Liberty Air are just one option in a true wireless earphone market that has tons of choices these days, so we've rounded up our pick of the best wire-free earphones to help you decide which you should get.
