How long does the Meta Quest 3S battery life last?
A Meta Quest 3S and its controllers with the retail box
How good is the Meta Quest 3S battery life?
Best answer: Meta claims that the Meta Quest 3S battery life lasts 2.5 hours per charge for normal gaming. We tested our Meta Quest 3S review unit for ourselves and found that it does last 2.5 hours in ideal conditions, such as standard gaming or streaming YouTube VR.
However, when playing a graphically intense, Quest 3-enhanced game, the Quest 3S battery life fell to 2 hours, closer to how long the Meta Quest 3 typically lasts. Heavily using mixed-reality passthrough, internet browsing, or other "productivity" software will burn through battery more quickly as well.
Why the Meta Quest 3S's battery life is better than the Quest 3's
Our Quest 3S reviewer Nick Sutrich ran the headset through several power cycles and agrees with Meta's assessment that the Quest 3S is more efficient than the Quest 3.
Article continues below
"On average, I got around two and a half hours of use from a single charge, with more power-hungry games like Batman Arkham Shadow bringing that down to around 2 hours," Nick explained.
For context, the Oculus Quest 2 also had a battery-life max of 2.5 hours with a last-gen Snapdragon XR2 CPU, with the same lenses & resolution as the Quest 3S but a smaller capacity (3,640mAh). However, most of these old headsets have lost battery capacity over the last few years, making the Quest 3S a return to the norm.
While 2–2.5 hours of playtime is enough for many Quest gamers, others will find it insufficient for long, immersive play sessions of the best Meta Quest games.
How to extend the Meta Quest 3 battery life
The Meta Quest v59 update added a Battery Saver mode that sets a fixed refresh rate (72Hz), brightness (50% of max), and reduced foveated rendering. You can find it in the full settings menu under Power if you need to stretch your limited Quest 3S battery life in a pinch.
This is a temporary compromise, not a long-term solution. If battery life is a regular issue, we recommend buying a replacement head strap with a built-in battery pack. Meta sells an official one for a costly $130.
Among the best 3rd-party Quest 3S accessories, our favorite is the BOBOVR M3 Pro, which costs significantly less. It's a huge comfort upgrade over the default Quest 3S cloth strap and adds another 5,200mAh of battery capacity, more than the Quest 3S itself has. It'll add another couple hours of playtime to the headset. It even has a quick-swap battery design, so if you pay extra for a second battery you can keep it charged and swap it in when the first battery dies.
You probably don't need the total 4–7 hours of playtime it potentially offers, but it gives you a buffer in case you forget to keep your Quest 3S charged and don't want to wait two hours to start.
Michael L Hicks
Senior Editor, Wearables & AR/VR
