GameKlip helps merge your Android phone and a PS3 controller
Using a Playstation 3 SixAxis controller with an Android device is nothing new. There have been methods around for a long old time on pairing the two devices for some all out Android gaming action. An app even exists in the Play Store nowadays to make the process even simpler. One aspect remains largely unchanged however, the phone is usually having to lie flat on a surface, or be propped up against something while you're playing. And that's not great.
We saw not all that long ago, a home-made solution designed for a Galaxy Note. It worked like a charm, but making stuff isn't for everyone. That's where GameKlip comes in, with their solution for a variety of Android phones. The GameKlip is simply a clip that allows you to secure your phone to the top of the your SixAxis controller for some gaming fun.
Oh, and as an added bonus, if you own a Samsung Galaxy S 3, it seems that you can use a GameKlip with a wired connection out of the box. No rooting, no third party apps, just plug and play. It should be easy enough to try out on other phones too, since essentially all you need is a USB OTG cable, and the USB cable that came with your PS3 controller. Says the official website:
Does my phone support a wired connection to the Dualshock3 controller?I have tested a wired connection with my AT&T Galaxy S3. I have seen videos of it working with the international version, and users have confirmed it is working on the Verizon Galaxy S3. I have not tested it with other phones, but I hear there are others that work. I recommend googling "your phone model + usb otg + sixaxis" or something similar. Most likely someone has tried connecting one already.
The GameKlip is available in wired ($23.00 / £15.99) and wireless ($15.00 / £10.49) play versions, and note that no software is included, it's just the clip. If your phone is lucky enough to work with a wired connection out of the box, then fantastic! For the rest of you, the old ways of connecting will still be required. Custom fitted for individual phones, the below are supported by GameKlip:
  • Galaxy SIII (All Variants)
  • Galaxy SII (Epic 4G Touch, Sprint)
  • Galaxy SII (Skyrocket, AT&T)
  • Galaxy SII (International)
  • Galaxy Nexus (HSPA+)
  • Galaxy Nexus (LTE)
  • Galaxy Note (AT&T)
  • HTC Evo 4G LTE (Sprint)
  • HTC One X (All Variants)
And, there's one more thing. The guy behind all this is working on a version for 7-inch tablets. That, we'd love to see. Pre-orders are open now, and there is international shipping available. So, if this is something that appeals, head over to the source link below for the full rundown.
Source: GameKlip via Pocket Gamer
